Ending raytraced prematurely
Hi David
I will do the test you requested but not today, I’m very busy at the moment.
PS Denoiser’s effect is not easily seen at the raytraced vieport, more obvious when render is running.
Hi @Piotr,
Any luck testing?
-David
I have tried yesterday, actually. Canceling Raytraced in V7 froze the session and I’ve had to kill it in a task manager.
Hi @Piotr,
Does this freeze happen every time? If it does, please create a crash dump like you’ve done before and send it to us.
There is a dump file, about 100MB. I will send it to you.
@Piotr,
It looks like VisualARQ is part of the call stack in the crash dump. If you load-protect VisualARQ, does Rhino stop freezing? Keep in mind that you need to restart Rhino after load-protecting the plug-in.
If Rhino is still freezing after load-protecting VisualARQ, please create another crash dump and send it to me through Supportbee again.
I will check it soon. Probaly after the weekend i will be rendering some more.
Sorry @Piotr - I meant Tibidabo.rhp, which I first thought was VisualARQ because I did some googling. But I’m not sure what it is. I think it’s safest to load-protect both Tibidabo.rhp and also VisualARQ.rhp.
I had some issues with VA (it is loading GH without my permission each time I launch new RH session) and I was advised by VA guys to disable Tibidabo, meaning it comes from them (whatever it is doing).
Disabling those two didn’t help. Rhino is still freezing.
Hi @Piotr,
Sorry for not getting back to you sooner. Are you still having issues with Raytraced + Denoisers?
-David
if it helps, i noticed raytracer freezing frequently when i cancel right away. if i give it a few moments to initialize properly it never freezes. i use mac tough and have non of the plugins installed also excluding denoiser.
i am certain it freezes in the render window, rather than using raytraced in the viewport but i am not sure anymore since i avoid canceling right away for a while now.
Hi David
Unfortunately, it still does.
Rhino comes completely dead and I have to kill it through the Task Manager.
It doesn’t show it is frozen, though.
This is what I am seeing 5 min. after switching Raytraced to Shaded (no escape pressed).
No type cursor blinking, just plain dead.
Piotr
PS: SR17
Let’s try to make sure we know whether the denoisers are causing this. Can you uninstall all denoisers and try again? Make sure when you restart Rhino that no denoisers are loaded by looking at the list of loaded plug-ins.
-David
Hi David
That was it!
I have completely uninstalled denoiser and I don’t see any problem now.
I can escape anytime or switch between the display modes.
Piotr
That’s good to hear! I would recommend installing the Intel Denoiser while we try to figure out why the AMD one is causing issues.
Just to report: Intel Denoiser works fine.
I have impression that it is slower, though.
