send to forum.3dm (222.0 KB)
Hi Forum, Try and use emap or curvature analysis. Getting unusual results. Thanks,Mark
Also trying to snap a line while surface points are on to a point. It will snap to some.
Hi John, can you turn the points on the surface and start line command and get the start point of the line to snap to any of the points turned on ? Thank you ,Mark
Yes, when using the Vertex osnap.
Thanks for checking. —Mark
