Doesn’t seem like it’s possible to snap a curve point to a position on a different curve that I’ve projected onto a surface. I’m moving the curve point by snapping to it first, then using End or Near snap to snap to the second (projected) curve. It doesn’t pick up on this. Nor does it work when I show the projected curve’s points, and try snapping to a curve point. It works only if I create a new point along the projected curve, then snap to that point. I think this is a bug - ?
I tried this, works OK here. I projected a curve onto a sphere, then moved another curve to intersect with this, using the ‘near’ osnap on both curves. No problem.
Max.
Edit: I tried the same with control points, works ok as well.
Hmmm. I’m trying it again right now, and it’s not working for me. I’m trying to snap the end point of one curve, to the end point of a projected curve. Using ‘End’ snap together with Move cmd, I move the desired point over the end point of the projected curve in the perspective view, and it doesn’t snap. ‘Near’ snap also doesn’t work.
Snapping an entire object does work, as I previously stated.
