ElmoSrf would be fun
Hopefully the “Elmo” tool will be capable to do a similar job with the surface, because at the moment converting degree 3 surfaces to single-span degree 6 surfaces results in a highly distorted output surface that are practically unusable.
Yes, I didn’t even tried Elmo, but I need ElmoSrf now! :smile:
Could you provide examples. Development is driven by bug reports with examples.
Attached is an example where a 11 x 11 points degree 3 surface is converted to single span degree 6.
Rebuild on the edge curve shows the same oscillation.
Right is Elmo with Smoothing Medium:
Elmo_test.3dm (172.5 KB)
Extreme distortion with chaotic position of the control points when converting to single-span surfaces has been reported multiple times in many topics over the past few years. Here is one of the topics which I started in 2022.
Extremely distorted Rebuild surface.3dm (181.4 KB)
That looks like an extruded surface. It could be handled by Elmo’ing an isocurve and extruding the result.
Yes, it was just the simplest possible example that I made quickly for the purpose of the bug report. However, in real case scenarios, Rhino users most often work with double-curved surfaces rather than straight extrusions. Having a proper “ElmoSrf” is crucial, especially for product design that relies on single-span surfaces.
