Element Type Picker - Other way to select an specific family type
Hi Guys,
Is there a component that I can add an specific family name without going to the element type picker and browse a long list of available revit family types?
Thanks
Yes just insert a Type component and Right clock and filter through the Families like the below:
Thanks Tay.0 the minor issue is hard to see the extend on the family name as I cannot grab the frame, any idea?
thanks
Hey @sketzjewel ,
I usually use the method mentioned above by Tay, but if you have an issue with long names or something else, you can have a look at the below component.
That is really quite handy! cheers Mohamed.
Hi @tay.othman not sure if I should be opening a new Forum topic but I will use you answer to ask a question since is correlated to the Topic. I noticed that my “Type” container or any other Container that have “type” option is not working while I have a model/template opened on my Revit 2022. So basically i cannot right click to select Type. It does work on Revit 2020 and also on Revit 2022 when I don’t have anything opened does anyone know what is going one? Thx in advance.
Hmmm can you check which version of RiR you have installed. I think I saw a loading problem with Revit 2022 in the daily build 1.6 likely a Revit issue but I was able to load the plugin. I’ll check it shortly and will let you know.
I used RhinoInside.Revit_1.14.8557.24642 and now I am at 1.12.8449.6358
Thank you very much for that
Hi Felipe,
Can you provide some additional info? Screenshot or files ideally.
Everything seems OK here in 2022.1
@Japhy It is hard to provide screen shots since the problem is when Right click and doenst show anything, I recorded a short video but icannot upload here. I have The screen shot of not been able when any project or template opened:
As you can see L (level give me an output but Type doesnt:
Now when I do the same thing when Revit is opened without nay Project/Template
I can
It also works on my Revit 2020.
Let me know how can I share the video I think might clarify
That helps, thanks.
If you are going that route, are you right clicking on the T input? I’m not seeing the issue.
I’m on a slightly newer build. I’ll check 1.14.8557.24642
Can you provide your about info? Rhino.Inside®.Revit
If you place a new component (from the same kind), does the right click work on it(new) and only on this component itself(old) it does not work ?
Hi @Japhy so that Screenshot is when I don’t have any Template/Project opened so the container works fine, the probleem is when I open a new project or a new template then the “TYPE” container or any container that contains Type doesn’t work. I am currently on version :
I downgraded form 1.14 since i was thinking the issue was due the update but it wasn’t
I mad a short video showing the issue just not sure how can I share here? Onedrive maybe?
Regards
Hi Mohamed it doesn’t work for any new or old component in the canvas.
is this specific to your script, what happens if you start a new Grasshopper definition here?
I’m running Revit 22.1.30.34 with RiR version 1.16 and everything works fine here.
Nope it is not, even when a nw canvas is opened. I know my co-workers don’t have this issue and I dont have the issue when opening on RVT2020 or even on 2022 when no projects are opened so if I just open Revit and run RiR it works. as soon I open a template or a project doesn’t work anymore
Are these default Revit Templates you are opening?
Can you remove any superfluous Revit Add-ons? If there is a conflict it typically appears on load, but perhaps this is something new.
Hi @Felipe_Melo,
We have added an error message box like this one to v1.16.
You can download it from the Rhino Inside Revit options dialog.
Please update and test with the new version.
A message box like this will show up in your case.
Please share it here to have more information about what is happening in your case.
No they are not but people that work with me can do pretty normally, we also noted that I cannot select more than 1 face using the face container and others can. I don’t have any conflict. do you have a list of Revit plugging that may cause it? I will compare with my Revit 2020 what I have installed but it is pretty strange . Do you recommend install RIR latest version?
Hi @kike Awesome I will do that as soon as I can and let you guys know. thank you for that.
