every time i use the Element type picker i get this error
Which version of Revit?
revit 2021
The general problem here is the the Type selector is an older component that only selects from the active document. So it is one of the components that will get confused when multiple docs are open.
When there is only one doc open, do you still see the errors?
We plan to rewrite the selector so it will work better in multi-docs environments.
it was happening with just one file open but it is resolved in the 0.1 build, I have used the component multiple times now and have not encountered the error again
Following this. Today I tried again and it worked, but I noticed something.
If you see my previous image “Basic Wall 300mm” is selected but this element is not actually present in the file so it’s obvious that this wont show nothing. I proceeded to select other kind of wall and it worked, but the component exception keeps showing every time introduce the element type picker in grasshopper.
When i open the file and some of the element type pickers are activated and fed by the built in category, all the exception warnings show on a row. Kind of annoying.
The element type picker that can’t read any element have this red warning:
“object reference not set to an instance of an object”
Then I select other element and go back to this one and the component doesn’t have the warning.
I just think this is a weird behavior. At least in my part.
I hope you check this out.
Thanks for the great info, makes it much easier to figure out what’s going on. I haven’t been able to reproduce it.
So the Element Type Picker is getting populated by Types in a file, then when you open the same definition in a new file sans types, it throws the exemption.
I am also having problems with the Element Type Picker (ETP) throwing and exceptions (A). But, this also makes some of the typing in Grasshopper unresponsive after plugging the
ETP into the script. I see that I get a warning error in the Rhino command line that gets stuck and refreshes ever few seconds (B).
I’m not sure if these two malfunctions are related but any time I’ve tried to use the ETP I loose some keyboard functionality and have to close Revit and Rhino and start over.
Rhino.Inside Revit: 1.3.7983.15227 (11/09/2021 08:27:34)
Rhino: 7.12.21313.06341 (Rhino 7)
Revit: 2021.2 (21.1.50.27)
