Elefront-Parameters not available on rhino properties panel
I am using Elefront 3.0.4 ,with rhino v5 SR14 64 bit/ GH0.9.0076
The Baked attribute to mesh rhino object are not available in the rhino/Properties panel!
Is there a way to see those Baked attributes in rhino .
Regards
Did you click on green post it ?
ElefrontProperties.rhp (138 KB)
This was provided by the Elefront Team for Rh 5
These parameters are stored under object’s UserText.
You have to use the GetUserText command in V5.
If you use V6, there is a new panel in object property to read/modify userTexts of selected objects.
The file i posted will provide this interface for rhino 5, so you don’t have to use the GetUserText command in V5.
encountered the same problem (Rhino 7), found these properties here:
