Changing, adding parameters to rhinoceros objects using a GH or plugins
Hello Guys
please tell me how can I change, supplement the parameters of the rhinoceros objects with the help of a grasshopper?
With any plugin?
You can bake objects with names and additional attributes using either Elefront or Human.
Thanks for the answer But the Elephant writes the parameters in the User Attributes section Text, marked in red
And not in the Options section
It’s called Elefront and the Object name is written into Object properties.
If you add other attributes, those are saved as Attribute user text.
Hi Alex -
That looks to be a tab added by VisualARQ.
