I have succeeded to load CSV data and generate squares by it. However, I now would like to bake (building) information into it. But it seems I have not understand the whole baking concept of elefront. Hope somebody can help…
There are several ways to attach your custom attributes. For example. you could generate custom UserValues and attach them to your objects. The component Define Object Attributes lets you define Layers, Names, Key & Values.
if the geometry is grafted (ideally down to 1 object) the corresponding attributes would be branched the same.
In the case above you would graft your User Values list & match up to a similar geometry branch/list. {0}[0],{1}[0],{2}[0],{3}[0]
if you have multiple User Keys the User Values would have the same amount of items per branch. 2 user keys, 2 items each branch for each single geometry branch.
Maybe I do not understand the core concept about this but your remark helped me. (that I also need to put the geometry into the tree structure). Below my sloppy solution. Thank you!
