EditListBox and OrderListBox in Rhino 7
In Rhino script 6 it was possible to create controls allowing you to add, delete and move the entry of a list.
https://developer.rhino3d.com/api/rhinoscript/user_interface_methods/orderlistbox.htm
or
https://developer.rhino3d.com/api/rhinoscript/user_interface_methods/editlistbox.htm
I can’t find the corresponding control in the Rhino 7 API, either with RhinoScript or RhinoCommon.
Does anyone know the name of the Eto.Form control?
merci,
jmv
It sounds like you could use a TreeGridView
self.m_treegridview = forms.TreeGridView()
self.m_treegridview.Size = drawing.Size(200, 200)
column1 = forms.GridColumn()
column1.HeaderText = 'Tree'
column1.Editable = True
column1.DataCell = forms.TextBoxCell(0)
self.m_treegridview.Columns.Add(column1)
# Add more columns
treecollection = forms.TreeGridItemCollection()
item1 = forms.TreeGridItem(Values=('coolnode1', 'coolnode2', 'coolnode3'))
# Add items and children
self.m_treegridview.DataStore = treecollection
Farouk
I don’t see a match in Eto so for now I’m writing a component with GridView.
But with TreeGridView or GridView, you need to implement MoveUp, MoveDown, Append, Delete logic.
With orderlisbox or editlistbox, this logic and buttons were integrated, which was convenient.
jmv
Hi @kitjmv,
Try this:
import Rhino
import scriptcontext as sc
import System
__rhinoscript__ = '1c7a3523-9a8f-4cec-a8e0-310f580536a7'
def OrderListBox():
    rs = Rhino.RhinoApp.GetPlugInObject(__rhinoscript__)
    if rs:
        list = System.Collections.Generic.List[System.String]()
        list.Add("Item0")
        list.Add("Item1")
        list.Add("Item2")
        list.Add("Item3")
        list.Add("Item4")
        result = rs.OrderListbox(list.ToArray(), "Drag items to move", "Order Items")
        print(result)
OrderListBox()
– Dale
Thanks @dale !
It’s exactly that. It works fine on Rhino 7, but not with Rhino 8…
jmv
Seems to work here in V8 using RunPythonScript.
– Dale
exact! It works this way.
I tested your code with RhinoCode and got this:
jmv
Make sure to use IronPython.
#! python 2
import System
import System.Collections.Generic
import Rhino
def OrderListBox():
    if rs:
        list.Add("Item0")
        list.Add("Item1")
        list.Add("Item2")
        list.Add("Item3")
        list.Add("Item4")
        print(result)
OrderListBox()
OK, I see,
PythonNet doesn’t let you get Windows objects but IronPython does.
merci Dale.
