Jon
May 9, 2018, 1:19am
1
Hi guys,
I’m using ColumnHeaderClick events to sort GridView columns. Works fine in the Rhino-5 plugin (referencing Eto & Eto.Wpf 2.4.1), but the events don’t seem to fire from Rhino-6. Has something changed? I see the Rhino-6 Eto libs have been incremented (2.4.6664.1688), but don’t see any documentation of this build online.
Cheers,
Jon
dale
(Dale Fugier)
May 9, 2018, 3:20pm
3
Hi @Jon ,
Something like this works here:
var grid = new GridView
AllowColumnReordering = false,
AllowMultipleSelection = false,
grid.BindDataContext(c => c.DataStore, (TestViewModel m) => m.Objects);
grid.SelectionChanged += (sender, args) =>
// TODO...
grid.ColumnHeaderClick += (sender, e) =>
// TODO...
Perhaps we need to see some sample code that isn’t working for you?
– Dale
Jon
May 9, 2018, 7:21pm
4
Thanks, Dale. Here’s some example code.
var items = new List<MyItem>
new MyItem { Name = "item1", Prop_1 = "some val" },
new MyItem { Name = "item2", Prop_1 = "some val" }
var grid = new MyGrid(items);
where
public class MyGrid : GridView
public MyGrid(List<MyItem> items)
// properties
GridLines = GridLines.Horizontal;
AllowColumnReordering = false;
AllowMultipleSelection = false;
DataStore = new ObservableCollection<MyItem>(items);
// columns
Columns.Add(new GridColumn
DataCell = new TextBoxCell { Binding = Binding.Property<MyItem, string>(r => r.Name) },
HeaderText = "Name"
DataCell = new TextBoxCell { Binding = Binding.Property<MyItem, string>(r => r.Prop_1) },
HeaderText = "Property 1"
// row selection
SelectionChanged += (s, e) =>
MessageBox.Show("this fires");
// column sorting
ColumnHeaderClick += (s, e) =>
MessageBox.Show("this fires in Rhino 5 (Eto 2.4.1), but not 6 (Eto 2.4.6...)");
and
public class MyItem
internal string Name { get; set; }
internal string Prop_1 { get; set; }
internal MyItem() { }
Thanks.
-Jon
curtisw
(Curtis Wensley)
May 29, 2018, 4:15pm
6
Hi @Jon ,
Sorry for the late reply, but you need to set GridColumn.Sortable = true for the ColumnHeaderClick event to fire.
The Eto that is included with Rhino is a custom build based on the develop branch on GitHub, since that allows us to get fixes into Rhino quicker.
Hope this helps!
Curtis.
