It happens since years, that Rhino for Mac is going to a 100% CPU load. Sometimes these strange bugs get fixed, but as we can see in the screenshot below, it now happened again.
I already had many discussions about this problem and each time it was a big hassle to find the source of the problem. Over the years I have invested hours just for this specific bug (strange 100% CPU usage for no reason) Now I have an idea / question:
Would it be possible to have a trace command in order to quickly find what process is causing the usage, similar to the activity monitor?
Regarding the problem itself: I just opened a file with some blocks and double-clicked one of the blocks.
I have posted my system info already 100 times, but here it is:
Rhino 8 SR7 2024-5-7 (Rhino 8, 8.7.24128.12262, Git hash:master @ 8bdee88d60977877d72ecc80dd756656929e0efb)
License type: Educational, build 2024-05-07
License details: Cloud Zoo
Apple macOS Version 14.4.1 (Build 23E224) (Physical RAM: 16GB)
Mac Model Identifier: MacBookPro16,1
Language: en
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5300M (4 GB)
Color LCD (2048 x 1280 @ 59.00Hz)
USB devices
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
com.intel.driver.EnergyDriver (3.7.0) 35E739F9-BF6C-3024-A67C-750711B3FB64
com.Cycling74.driver.Soundflower (2) 2D779840-7439-31E5-8A66-D786C3F47B75
com.paragon-software.filesystems.ntfs (149.8.15) B3791A17-53DF-3B03-9FF5-298D092ECF8C
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libkaramba.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libiomp5.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libmetis.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libarpack.2.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libc++.1.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libopenblas-r1.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libgfortran.5.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libgcc_s.1.1.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libquadmath.0.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libc++abi.1.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 8.7.24128.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 8.7.24128.12262
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 8.7.24128.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp "RhinoCodePlugin" 8.7.24128.12262
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 8.7.24128.12262
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 8.7.24128.12262
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp "BlockEdit" 8.7.24128.12262
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 8.7.24128.12262
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 8.7.24128.12262
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp "AnimationTools" 8.7.24128.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp "SectionTools" 8.7.24128.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp "Legacy Rhino Render" 8.7.24128.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp "AutoCAD file export : export_ACAD" 8.7.24128.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp "Displacement" 8.7.24128.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STEP.rhp "STEP Import" 8.7.24128.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_ACAD.rhp "AutoCAD file import: import_ACAD" 8.7.24128.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 8.7.24128.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 8.7.24128.12262
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 8.7.24128.12262
