Recently I discovered that you can customize the shortcuts, but in the case of delete does not allow me to use backspace. instead of delete, compared to the MAC version that uses it as a default.
The reason is because for Bootcamp users, delete is (fn+backspace) and it’s not efficient.
So any chance to fix this, it would be good, because inside Rhino bootcamp, backspace works as delete by default, if not only that you can edit the delete shortcut would be excellent.
Regards
Mac version
Windows
