Edge Will Not Fillet
In the enclosed file, you will see two edges circled in red that will not fillet. They will not even select for filleting. Can someone tell me what’s going on?
thanks,
rex
Hose Support 2nd Trymcn.3dm (2.1 MB)
Hi Rex - you need to join that face there to the rest of the polysurface.
Dang, didn’t notice that. I wouldn’t
Hose Support 2nd Trymcn.3dm (1.5 MB)
have thought the boolean union would work if that surface wasn’t attached.
One more thing on the new attachment. The circled corner has a messed up fillet. This is due to some local naked edges which I’ve now fixed. However, I now can’t get the fillet right without backing up a long ways. Is there a easy way to fix this?
thanks
Hi Rex, yes - to clean up, DupEdge and SimplifyCrv an edge of one ofthe existing fillets and Revolve that 90 degrees:
Use the edges of that surface to trim the ‘parent’ polysurface
