Edge surface cannot make a full surface and so I am having problem with the brep
Hello everyone,
I tryed to make a edge surface from those top curves but the result wasnt quite regular and this resulted on a sloppy brep afterall. Is there a way to get a regular surface in this case so I can fillet the brep edges without the picture problem?
Thanks
decaybox.gh (19.5 KB)
P.S. I don’t see any problem here with EdgeSrf, the problem is how does one fillet such an awkward shape?
You could trim the “sloppy” fillet like this (white group):
decaybox_2020May25a.gh (29.5 KB)
And there are more edges of that cube that could be filleted but I would use a text panel list of edge indicies rather than a bunch of sliders. Use the included ‘Tree/List Viewer’ tool to find more edges that could easily be filleted
decaybox_2020May25b.gh (34.1 KB)
Or like this, if you want cleaner result…
decaybox_RE.gh (23.4 KB)
by saying problem of the surface i mean that the surface could not be made as one unit and is segmented.
Thanks for the solution
thanks man, its way simpler
