Hi all,
I am trying to do a simulation in Eddy 3D and am unable to run it due to this error
Solution exception:Input parameter index [-1] too low for Component Residuals.
Would appreciate any help with this- thank you!
Ros
Thank you so much- that solved that part of the problem! However there are new error messages:
it says " “C:\Eddy3D-Cases\3_SimpleWindAnalysis\19\postProcessing\ttt\0\U” does not exist. Please run the probing component." I did run the simulation, but am not sure what the probing component is referring to. Really a noob to all these- any help is appreciated, thank you!
I had the same error. to control the process i switched to using boolean toogle False/true. I can send you the gh file i made to see if it works. hope it works. and if not I will check again
CFD IN URBAN.gh (43.9 KB)
Thank you for your help! Let me try it out ![]()
I think it’s because the number of iteration you set was too low, you should increase your iteration to probably over 500?
