The mesh folder does not exist. Please create a mesh first
emmm…i don’t know how to solve
Same error here. Not sure what I’m doing wrong. Do we need to download another piece of software for Eddy to use?
Any developments on this ?? I’m getting the same error.
That’s what I was thinking.
But I have downloaded Eddy 3D installer , blueCFD2020 and Radiance.
All these downloads were also “run as administrator” so as to ensure they are fully installed.
However, this problem still persist.
This happens usually when your simulation didn’t run properly. Can you see the graph? did it run properly?
Hit the button for Paraview and see if any data is coming inside. If you don’t see any results it’s probably because your run didn’t work.
Try redoing it, make sure you delete the old folder or create a new one for this run.
There are few things that I did that have fixed this, (take note; I am using Rhino 7 )
1) Changed the Probing to Eddy3D Version 0.3.8.0
2) Change the Simulation to Eddy3D Version 0.3.7.0
3) Ensured that I added blueCFD-core-2017 into the correct pathway (image 1), as stated on the website, while also pointing the Eddy3D Plug-In on Rhino7 into the correct directory(image 2).
image 1
image 2
4) Ran the Mesh & Simulation (image3) first, waited for the iterations to finish, and then ran Probing (image 4)
image 3
image 4
Apologies that I could not be more specific, I was frantically trying to figure this out.
Happy simulating! & Goodluck!
Hi
I’m getting same error, even on the default pre-set
I have fixed all things you mentioned except probing version witch is 0.3.7.0
how can I change the version
(Im using Rhino 7, eddy3d main branch downloaded from eddy3d.com)
I’ve also tried on rhino 6 and eddy3d version 0.4.1.1
I get this error in Paraview at the same time
Warning: In C:\bbd\2d618e80\build\superbuild\paraview\src\ParaViewCore\ServerManager\Rendering\vtkSMPVRepresentationProxy.cxx, line 276
vtkSMPVRepresentationProxy (00000266470BF190): Could not determine array range.
Hey
Hope you managed to fix the error! and thank you Khawaja Mohsin for the tip- it helped! As for changing the probing to 0.3.8.0 - I simply deleted the existing one and searched “probing” in the grasshopper canvas. You should find the correct one there:)
hiii i want to try this but idk how to change the vers!
I am pretty sure the simulations are not running properly or at all. when i click run, there is a black terminal window opening and then disappearing within a second. Also nothing happens when clicking the paraview toggle.
i too got this issue, did you find a solution for this?
okay so i did get a solution for this. For me its was using rhino8 that was causing all these issue only, as soon as i switched back to rhino7 it worked very smoothly.
Hope this helps.
good to know to switch to r7 worked, but obviously not a real solution if your already committed to build the script in r8 (with all it’s benefits). I did notice that when changing the name from the default “ttt” from the template this also triggered some additional errors of not finding required files or paths. Hope @eddy3d or McNeel can support us on this, as when searching the discourse for issue when using Eddy3d, lost of users have similar issues on this
same issue “The mesh folder does not exist.“. it’s working with Rhino7, but with Rhino8 not.
