Easy export as DWG
Hey hey. I was looking into automating some operations and figured I could do it to export documentation dwg files, my issue is that using the standard “export as dwg” pre set option I get the text objects without the Font I used originally, any way to correct that?
This is something I have noticed as well.
Styles are not exporting properly in .dwg format. Text styles and dimension styles.
Often the dimension exports with the right style name, but does not display with that style.
Same with text.
This happens with a V12 dwg export, as well as with a 2007 dwg export.
I have assumed that this is an AutoCAD frustration feature inserted to encourage “trusted” dwg use only.
