Dynamic Spot Coordinate, Spot Elevation, X,Y,Z annotation blocks for R8
Been meaning to upload these nice dynamic annotation blocks @wim gave me a tip about -
Spot Coordinate & Spot Elevation Blocks.3dm (104.3 KB)
Feel free to customise.
How to make the dynamic annotation component/s:
  • Run Text
  • Paste this: %<PointCoordinate(“Block”,“X,Y,Z”)>% (delete X,Y,Z as required)
  • Turn the text into a block
Note that pasting in the forum creates curly quotes that need to be replaced with straight quotes when pasting back into Rhino.
Hi Hugh,
Maybe this routine will help
block_name = "BlockName"
coords = "X,Y,Z"  # Change to "X", "Y", or "Z" as needed
dynamic_text = '%<PointCoordinate("{0}","{1}")>%'.format(block_name, coords)
base_point = (0, 0, 0)  # Starting point for the text
text_height = 1.0  # Text height in model units
text_object = rs.AddText(dynamic_text, base_point, text_height)
block_name = "DynamicAnnotationBlock"
if text_object:
    rs.AddBlock([text_object], base_point, block_name)
    print("Dynamic annotation block created successfully!")
else:
    print("Failed to create text object.")
Farouk
Thanks for this @farouk.serragedine. Forgive my ignorance but would you be able to share a step by step ‘for dummies’ breakdown of how to use a routine like this? Would it be saved as a .txt file then dragged into the command line…?
@wim I am wondering whether there might be a way to use this dynamic block function to create a slope annotation tool…?
Thank you, super helpful and simple.
