I am trying to achieve following without success. Tried Bumblebee GHexcel plugins…
-there is excel file with given filepath and it is constantly changed because it is results from analysis software
-i need to dynamically read that excel file into grasshopper so it reacts and updates when the file is changed
-the file cannot be open it has to be done in the background because its constatly overwritten by the analysis soft
-Bumblebee and GHexcel can do this only when excel sheet is open
I need to establish optimization loop – parameters change --> export --> analyze (results are saved in excel) --> import results --> optimize (octopus) —> change parameters …
without this function there is probably no way how to achieve it
it will update when there is change in gh component which triggers analyses … so when analyses is done there is new output message and then excel will be read which will trigger another event
