The DXF export Wip crashes my rd works laser software
the same file export from R8 woks ok , i have used the dxf settings from R8 into R9
enclosed both files the R8 is much larger , maybe the dxf export is not complete , but i can read in the dxf file complete as exported by 9 but not in rd works that crashes why are the files not the same size ? same settings
v8 curves are a mix of polylines, arcs, and circles. v9 curves are mostly NURBS with a few arcs mixed in where tips are filleted. The lines are consistent in both files.
This may not be the correct thread to drop this but may save anyone struggling with export DWG and DXF fonts and texts out of rhino into a CAM program like RDworks.
We ususally use the CAM metric defaults exports without issue but came into an with some fonts not presenting correctly. The issue is not the type of font but its scale. Discovered a work around, export it larger and then rescale in RDworks.
no doubt its the something to do with the Maximum Angle, Chord height setting and a simplyline and acrs tolerances but don’t fully understand and by which point i was export version 18. If theres someone smart enough to explain it, would love to hear it.
Anyway if this helps anyone else or therese a more appropriate thread to stick this let me know.
I tested your INI in v8 and v9 using your 3DM, the output curves is a mix of polylines, arcs, and circles. This matches exactly your previous file ST7 2mm Rhino 8.dxf. I used SelDupAll to compare.
The size difference results from the AutoCAD version, and the type of entities that are exported. The 2 DXF example files you provided are saved as version 2009 for the file name ST7 2mm Rhino 8.dxf and version 2018 for ST7 2mm Rhino 9.dxf. The version is listed as AC10xx, the last 2 digits indicating the version. Note that after version 14, the convention changes for indicating the version listed in the file. To get the actual version that corresponds to the year, 14 must be subtracted. So version 18 is displayed in the file as AC1032. If you read the DXF files with a text editor, the version is listed within the first few lines.
After using your INI in both V8 and V9, the AutoCAD version that is saved is 14.Your INI indicates version 12, so its not exporting the version you have indicated in INI, assuming the you included is the same INI that produced the DXF files you included.
well simply said , i have used the settings in R8 for R9 , acad 12 , for both and i even exported the R8 settings to import in R9 so what can go wrong ?
obviously a lot so R9 does not export the correct way as i assume now.will have more testing asap as it is not ok
btw i used for both versions Cam metric (r12) as i use this for many years and it works ok
well i have changed some settings and now it is working also installed a new version of rd works , no problems now and small dxf files , so it looks good there must be some tiny setting that was not seen
