DWG to Point Cloud
Hi Guys,
New Rhino user (education purposes).
I’m wondering how to go from a DWG model (made in CAD) to a point cloud?
I read a few forums outside this and apparently it’s possible in Rhino. Obviously the reverse is common practice, but I’m wondering if anyone knows how to derive a point cloud from a 3D model.
Kind Regards,
McLaren
Hi
This is a very strange request without a context as to why you would want to do this.
What problem are you trying to solve by getting points from a file?
To answer your question, you can select everything (SelAll) and run ExtractPt to generate the points.
Then SelNone, SelPt, Export
Hi Duncan,
if your import is a mesh, try _ExtractPt and _PointCloud, this should even work for surfaces or polysurfaces if they have enough control points.
c.
Thank you very much John and Clement, these solutions work well.
I wanted to compare a 3D model with a laser scan point cloud (same building) using Cloudcompare.
Point comparisons tend to be the most raw/ unedited way of carrying out such analysis.
Thanks again,
McLaren
Be aware that some of the points are not on the surface or curves, they will be a Control Point locations. This might introduce error that isn’t really there.
You’re probably pretty safe coming from a DXF or DWG file sine there will be no NURBS surfaces or curves in it. Mesh objects will have points on the vertex corners.
And you can convert NURBS to meshes and then extract the points from that.
