Dwg that I download online open empty in Rhino
Please help! When I download any kind of document online (like 3d city maps or technical details) they open in rhino as an empty file. On the command box it says: Loading Rhino Render, version 1.50, Nov 10 2020, 17:22:31
Blocking plug-in AutoCAD file import: import_ACAD.
Please run the Rhino SystemInfo command and post the results.
Also, please post a small example file that shows the problem.
Thanks
Hi -
First, please check and make sure that the plug-in is enabled in the Rhino PluginManager.
If that is as it should, try with the Enscape plug-in disabled (you need to restart Rhino for these changes).
If all this fails, you can try to repair the Rhino installation. From the Windows Control Panel > Programs > Uninstall a program, you can pick Change and then Repair.
It happened with me one I tried to drag and drop DWG file from an archived compressed file and After extracting files it worked smoothly
