DWG Export Leaders Issue
I’m having another issue, maybe related to this original issue. When I export dimensions to DWG, the dimensions often get modified so that both points are moved to 0,0. So, pretty much all dimensions are unusable when exported to DWG.
Version 8 SR28
(8.28.26041.11001, 2026-02-10)
Looks like this in Rhino
Then looks like this in AutoCAD
Hi Jake -
Could you post a 3dm file with dimensions that show that behavior?
01 Hold Level.3dm (1.8 MB)
01 Hold Level.dwg (162.4 KB)
I suspect this may have something to do with my export settings. I was able to produce different behavior when using different settings that did no project to CPlane.
Please also note that ‘Project to Cplane’ option does not project blocks to CPlane in the resulting dwg.
13105ExportDWG.ini (988 Bytes)
