Sequence:
- In Rhino, Open a File
- File --> Duplicate
Problem:
- Dialog Window is missing (only a little space for entering the filename)
system.txt (2.7 KB)
Sequence:
Problem:
system.txt (2.7 KB)
Thanks
Added to the heap:
https://mcneel.myjetbrains.com/youtrack/issue/RH-56394
@Peugeot
The developer took a look and could not repeat the error.
I could the other day so reported it.
Today, I’m unable to repeat the issue.
Can you repeat it?
If so, please record the specific steps needed, a screenshot of the About Rhino dialog, and your macOS version number.
Thanks
I think I see it now.
You’re running with your Rhino application Maximized, so when the new file window is created, it superimposes over the first.
That is a bug but not as big a deal.
Try it again without Rhino maximized. It can fill most of the screen but leave enough room so a new Rhino file window can be offset from the original.
Is that different?
