Duplicate blocks selection
Is there anything like to select duplicate blocks? The duplicates object does not work for blocks.
Thanks.
In case you have Rhino 8.5, you’ll now see the number of block instances in the block definitions panel.
Hi @Hassan_Nawaz ,
In the Block Manager, find the block instance name, Right click and choose “Select Block Instances”.
Hope that helps!
Thanks, yeah that was quite helpful. Thanks to both of you @martinsiegrist @michaelvollrath
