Hello - if you remove control points from a curve by just deleting them, there’s a good chance that the resulting curve will have non-uniform knots - making a new curve snapping to the same points will make a uniform curve.When curves or surfaces are non-uniform, the points are not so ‘well behaved’… RemoveControlPoint might be a better choice than just delete - I have to check but I think that may also make the result uniform.
