Blended two curves with joining option.
At the joint of the curves, the point is a kink.
To remove the kink, rebuilt the curve with same point count and same degree.
Is this a correct approach?
Rebuilding will change the shape of the entire joined curve. Better would be to use Match and match the curve ends curvature continuous; check “merge” to make them into one curve after the match.
HTH, --Mitch
Got it. Thanks!
