Hello @karamba3d;
I tried to export a 2D FRAME in Karamba 1.3.2 subjected to a globally projected load. In RSTAB (imported with default z axis) I obtained a globally oriented load however on the true length of the member. I could see that this imported load was not all over the beam. Do you think this the problem is with DStV EXPORT Karamba or in RSTAB?
Regards,
Veronika Phadtare
