Block loads on two beams - Graphical inconsistency or wrong script?
Hi dear Karamba3d - Users,
I’m facing the following problem:
when I try to visualize the distrbuted loads on two beams, and I’m flattening the Loads-Input, the right side doesn’t show the same value anymore. If I were to not flatten them, the view is like on the second picture - overlapping.
More further - the reactions on the right side seem to be rounded up or down to the next integer number… The left side is showing correct values…
What are your thoughts about that? Am I doing something wrong with the lists organisation?
Thank you!
Demo.gh (37.9 KB)
Hi, did you make sure to select the correct Loadcase in your ModelView. The default loadcase is a combination of all loadcases
