Is there a way to show in the drawaing hidden geometries or the geometries which are below others in dashed line type?
my code works by exploding each geometries and extracting edges and removing duplicates curves/polyllines
2D_TopView.gh (11.1 MB)
Hi @anon76319893 ,
I haven’t had a chance to look at your GH file but you can use the Technical Display Mode in Rhino 8 which will show hidden lines beyond as dashed.
It supports vector printing as well.
Alternatively, Make2D
Alternatively again, if you know which lines are supposed to be “hidden” set those as a hidden linetype in R8 with the new Model Linetype components.
For R7 you could also use Human plugin or a Python, or C# script.
Hope that helps you as a jumping off point!
Not sure I understood if you’re trying to simulate what Make2D does, which means you could simply use Make2D within GH as suggested by @michaelvollrath ?
Alternatively, you can also use the Dash Pattern (Dash) on the curves you know are below:
