I am a Autocad 2D veteran and young to Autocad 3D & new to Rhino.
I am very impressed by the sophisticated function of Rhino in 3D compared with Autocad.
I have difficulties in modelling a Rectangular Hollow section in Rhino but I can do it in Autocad. Anyone can tell me the equivalent command in Rhino?
First of all, I draw 2 different size rectangles with the same center.
Autocad command - region = Rhino command - ?
Autocad command - subtract = Rhino command - ?
An entity plan will be created and ready for extrusion.
Autocad command - extrude or presspull = Rhino command - ?
An Entity Rectangular Hollow Section created.
Anyone can tell me the equivalent command in Rhino.
Thanks
As far as I can tell, you only need to use ExtrudeCrv
on both curves in one go to obtain what you need. Set the solid
option to yes
Apart from that:
- region: could be
CurveBoolean
in this case the result would be the same as the two original circles. Or perhaps two circular planar surfaces - what does AutoCad do with this? - subtract:
BooleanDifference
if performed on two circular planar surfaces like in this case, this will result in a doughnut surface (circular srf with hole in) - extrude:
ExtrudeCrv
Hi Ken - Rectangle, followed by Offset, then with both selected, ExtrudeCrv, Solid=Yes.
Is that it?
Thanks, this command is very useful.
The concept of drawing is something different from Autocad.
