Draw Perpendicular lines on a curve on specific points
Hello All,
I have a set of curves and points in Rhino. I’m not dividing the curves in GH to get the points and the spacing is different on each.
What I would like to have is to get the vector that is perpendicular to each of these curves, and draw a curve in that perpendicular direction, starting from these points.
So this is what it would look like at the end:
For the corner points, I would like to generate a bisecting curve like this:
How can I achieve this? Thank you all in advance. Here is the GH file with internalized geometry:
drawperpcurveonpoint.gh (10.1 KB)
Best,
Renan
Moved to Grasshopper category.
Here’s one way:
drawperpcurveonpoint_221118_re.gh (12.3 KB)
-Kevin
Noticed that previous definition didn’t work if the direction of the curve was reversed. This corrects that shortcoming.
drawperpcurveonpoint_221118_re2.gh (15.8 KB)
Different logic would be needed if lines don’t form a closed curve.
-Kevin
Hi Kevin,
This is awesome, thank you so much!!!
Renan
