Hello All,
I’m looking for an effective way to draw curves in Grasshopper.
Usually in Rhino I like to drag the control points of a curve in order to achieve the desired result and I’m trying to find a way to parametrize this process.
In the attached file there’s a simple exampl, a wheel, placed on its final position. What I did was to create a plane, which is placed on the hub of the wheel, then I moved the origin point in the two directions to create a set of points, so the curve and the revolution.
Well. Is there a better way for this? I see some tutorials with the Graph Mapper component in use, but I don’t understand if it’s aligned with my intent.
Thank you!
Test1.gh (10.9 KB)
