Draw and modify curves on surface - Rhino 7
In Rhino 7 is there a way in which I can move a line that has been projected onto a complex 3D surface (in this case an organic shape with a complex topography) and keep the line constrained to the surface?
When I try to move the control points of such a line, they do not stay on the surface and I have to use “pull” to bring them back onto the surface. For complex lines this can be very time consuming.
Similarly for InterpCrvOnSrf, if I try to alter the initial line, it usually ends up not being on the surface after being edited.
I wondered if anyone knows of a way to almost treat the surface of an object as a C-Plane so that any points or lines I create/move Rhino automatically stay on on a surface.
Otherwise any hints to make this easier would be much appreciated!
I found this link for Rhino 6 which looks like exactly what I want, but it doesn’t seem to work on Rhino 7:
Also if it helps - what I’m trying to do is design a shoe upper pattern on a last. I can import a sketch with my lines, trace the lines and project onto the last, but from there if I want to modify any of the lines it takes a lot of time and effort. If there is a setting to tell Rhino to constrain any edits made to lines to the surface it would be incredible!
Many thanks
maybe you can try using a surface instead of a curve, and get their intersection curve (which for sure lies on the second srf as long as they intersect) ?
Very helpful suggestion, thank you.
What I’ve done is:
  • In a side viewport, created the line that will form my design
  • Turn on History
  • Use Ribbon to make a surface from this line which is wide enough to intersect with the surface I want to design on
  • Due to history, when I change the original line, the surface (created by Ribbon) changes with it
  • When it looks good, I can use Intersect to generate the line I’m interested in
  • It’s not perfect but is much, much better than what I was trying to do before!
Thanks again
Project a curve with history on and then adjusting the input curve may also be an option.
Thank you. Seems similar to the use of ribbon above, though have I missed something?
CurveOnSurface V6 now works on V7. https://www.food4rhino.com/app/curveonsurface-0
CurveOnSurfacePtOn which only works with curves created by CurveOnSurface
I had to admit I hadn’t tried - one of the comments on the download page asked when it was to be upgraded for R7 so assumed (always a dangerous thing) that it didn’t work.
Just downloaded and tried and it’s exactly what I was after.
Thank you, marked this comment as the solution.
is there a plug in rhino7 for Mac? would be great
