I have a technical question and I hope I can explain it properly… Is it possible to turn the control points on a curve on a single but complex surface surface and manipulate those control points and have the curve stick to the surface (for the lack of a better term)? Does Rhino7 have that option?
Apart from that, you can turn the surface points on, select the row or column that you are interested in, invert the selection and use HidePt to hide all other points. You then have your single “curve” of control points that you want to edit.
CurveOnSurface plug-in, available free at Food4Rhino, provides the desired functionality for curves created using the plug-in on single surface but not on a polysurface.
