Drape question / Request
Hi all,
I use the Drape command quite often—it solves problems that would otherwise take ages to model manually. However, the current rectangular bounding box has a few limitations.
A couple of questions / feature requests:
  1. Non-orthogonal boundary: Is it computationally necessary for the base boundary to be an orthogonal rectangle? Could we have an option to define an oriented rectangle or an arbitrary 4-point boundary?
  2. Custom base surface: Would it be possible to select an existing surface as the starting geometry rather than generating a flat grid from scratch?
Having these options would make Drape significantly more versatile.
Thanks!
This one of the long forgotten tools in Rhino. I guess that it’s based on voxels or a similar approach to calculate the pixel-like structure.
Ability to use existing rectangle curve would be welcome.
Also, ability to snap the two opposite corners to other geometry (as if you build a basic rectangle).
Subsequent History-based editing of the size must be added, too. And editing of the XY resolution.
Also, ability to change the projection angle and axial rotation.
One hugely important feature is to add an optional overbuiding! Sort of an UV offset, i.e. extending the sides by a set distance. For example, if I want to create a drape surface from a rectangle that covers 60x40 mm, I must be able to set a custom offset (overbuilding) such like 5 mm at each side, so that the end surface will become 70x50 mm large.
spb_Drape.py
and its equivalent plug-in command, ccDrape of CADacombs
_-PackageManager _Search CADacombs
allow for a starting surface and have elevation options for where the draped surface doesn’t have target geometry to drape upon.
Also, see Wishes for the "Drape" tool
Hi Steven, thanks a lot for sharing this.
I think you sent me your scripts to test about 5 ago and I was a little confused about how to use them.
Now I downloaded your plugin and it seems more mature and easy to use.
The ccDrape seems exactly what I was looking for.
Thanks again!
