Drag and drop BUG
When I drag and drop rhino (3dm) file into rhino (latest rhino 8 release, mac) and press cancel, file still opens.
Rhino 8 SR33 2026-7-7 (Rhino 8, 8.33.26188.13002, Git hash:master @ 482f88a83547c62cde64d78ea8a8690b7349f289)
License type: Commercial, build 2026-07-07
License details: Stand-Alone
Apple macOS Version 26.5.2 (Build 25F84) (Physical RAM: 8GB)
Mac Model Identifier: Mac14,2
Language: en-UA (MacOS default)
.NET 8.0.14
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2
Color LCD (1470 x 956 @ 60.00Hz)
C34A1R+ (3440 x 1440 @ 60.00Hz)
GPU Vendor: Apple
USB devices
Apple Inc.: iPhone
VLI Inc.: USB 2.0 BILLBOARD
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_DarwinFoundation1.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswift_DarwinFoundation2.dylib
/usr/lib/swift/libswift_DarwinFoundation3.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswiftCoreMediaIO.dylib
/usr/lib/swift/libswiftCallKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/updaters/libAppleTconUARPUpdater.dylib
/usr/lib/updaters/libT200Updater.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/ivangrebennikov/Library/Application Support/McNeel/Rhinoceros/8.0/Plug-ins/Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)/Libraries/GHGPU/MetalBridge.dylib
/Users/ivangrebennikov/Library/Application Support/McNeel/Rhinoceros/8.0/Plug-ins/Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)/Libraries/GIA/Vectorize/libVectorizeLib.dylib
/private/tmp/mm-exhelper.dylib.On4bgD
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	8.33.26188.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	8.33.26188.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	8.33.26188.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	8.33.26188.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp	"MeshCommands"	8.33.26188.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp	"PDF Export"	8.33.26188.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	8.33.26188.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	8.33.26188.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp	"AnimationTools"	8.33.26188.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp	"SectionTools"	8.33.26188.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp	"Legacy Rhino Render"	8.33.26188.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp	"Rhino Labs Tools"	8.33.26188.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp	"AutoCAD file export : export_ACAD"	8.33.26188.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp	"Displacement"	8.33.26188.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STEP.rhp	"STEP Import"	8.33.26188.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	8.33.26188.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	8.33.26188.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	8.33.26188.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp	"RhinoCodePlugin"	8.33.26188.13002
Thank you for your report. I couldn’t reproduce this issue in Rhino 8.35 Mac. I’ve sent the download link via DM, so pls feel free to test it when you get a chance. Thanks!
Just tested on 8.35
Still happens..
Could you please reset Rhino for Mac to factory settings using the Reset command, and then see if the issue persists? Thank you.
It is the first time i am resetting rhino to defaults. And what i did not expect, is all my gh user objects being deleted one by one, without being able to do anyhting. Is there any chance i can restore them?..
It did not give any warning, i had over a hundred user objects
I found backup folder.
‘/Users/user/Library/Application Support/McNeel/Rhinoceros/8.0backup 2026-08-06-10-02-00/Plug-ins/Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)’
Thank god
Full reset did not fix that for me, cancel still does not do anything
After testing further, I found that I can reproduce this issue on my MacBook Air as well. I have filed a YT with our development engineers. Thank you again.
RH-97566 File: Drag and drop BUG
