When I try to open a grasshopper file via dragging and dropping to Grasshopper window it instantly causes Rhino to crash. It happens with every file, both downloaded or created locally. Opening the file via double clicking does not cause any problems and all files open.
Uploaded the crash report below.
Crash Report.txt (113.1 KB)
Japhy
(Japhy)
March 20, 2024, 7:27pm
2
Hi Bera, Can you run SystemInfo in your Rhino command line and post the results? Thanks
Here:
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13002, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Educational, build 2024-03-12
License details: Cloud Zoo
Apple macOS Version 14.4 (Build 23E214) (Physical RAM: 16GB)
Mac Model Identifier: MacBookPro18,1
Language: en-TR (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Pro
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
Logitech: USB Receiver
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp "RhinoCodePlugin" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp "AnimationTools" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp "SectionTools" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp "Legacy Rhino Render" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp "Displacement" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 8.5.24072.13002
Japhy
(Japhy)
March 20, 2024, 8:49pm
4
Thanks, I just dragged a simple .gh file with no issues.
Are you dragging into gh already started (which i did) or into Rhino itself?
Does this happen with a simple .gh file? Add a box, save file and give it a go please.
Are you running a lot of 3rd party Grasshopper addins? Are they all mac compatible?
Try starting Grasshopper with GrasshopperLoadOneByOne and say no to all 3rd party plugins
11159
(Masaki)
March 21, 2024, 5:17am
5
On my Mac(M1 MacMini) Rhino8 SR5 (8.5.24072.13002, 2024-03-12), dragging a gh file into GH’s Canvas causes crash too.
However, when I upgraded to version 8 (8.6.24074.01002, 2024-03-14), which is a service release candidate, the problem was solved.
It happens when dragging gh file into grasshopper canvas. I don’t have any 3rd party addons. Here’s the scenario:
Open a new Rhino file.
Launch Grasshopper.
Drag any gh file into Grasshopper.
wim
(Wim Dekeyser)
March 21, 2024, 10:50am
7
Hi Bera -
Masaki wrote that the problem went away by updating to the latest service release candidate. Could you give that a go?
Hi Wim,
I’d rather wait for final release than to use release candidate. I can avoid using drag & drop for a while. Thanks.
I was getting that drag&drop crash as well but this appears to be fixed in the latest release.
Version 8 (8.6.24101.05002, 2024-04-10)
