After downloading the file Rhinoceros_5A857.dmg, I double click to open and mount the disk image but it does not. I get an error message on the Console as follows:
I am not a newbie Mac user, but I cannot find any solution on the web for this, although I do see similar Console outputs. I have downloaded it twice with the same results. It seems to be a relatively new release. Could the DMG bundle have been damaged?
Has anyone downloaded Rhinoceros_5A857.dmg and got it to open successfully?
I am on Mac OS X 10.9.5 (Mavericks) with a Mac Pro 2009 with 8-core 2.26GHz CPU and 20GB memory
Well, this is strange. Just about 30 minutes before I got your reply, I was playing around and I had some older version Rhino DMG files so I double clicked those and they did the verify/load thing. I closed the virtual disks and tried the 5A857 dmg again and it worked! I donāt know what changed since yesterday. i didnāt reboot or install anything new. I donāt know if mounting the other DMG files set some preference somewhere or not. I just ran a verify via Disk Utility and it checked out with a CRC32 code of $0B271CD
Thanks for your suggestion. I missed that in the wiki. Although I did not get the āCanāt open the disk imageā error. I got nothing at all. I double clicked the dmg file and Finder switched away from the finder window and then did nothing.
Thanks for explaining what took place before it worked⦠@dan@marlin any thoughts on what might be happening in these cases? Could it be due to a previous disk image of the installer not ejecting fully? Iām making stuff up here and havenāt tried to reproduce this yet.
Sounds sort of plausible. I really donāt know what is causing thisā¦I could speculate, but thatās not very constructive. For meā¦this is the weirdest part:
Iām glad itās working now. I guess we have our own form of āinstaller issue.ā
Same thing with 5.0.1. Double clicked, finder changed focus, then nothing.
Double Clicked a previous build, it launched, THEN 5.01ās DMG Launched.
Whatās odd is I got the license agreement from the previous build, but NOT for the 5.01 DMG, although it did mount.
I was able to copy 5.0.1 over the previous version and it starts to launch then just bounces forever in the dock and does not run.
Activity monitor shows it as having 1 thread, and 0 CPU % and Time.
I ended up force quitting it.
Next I launched the previous WIP, got the āupdate availableā bit, which was odd:
Which is odd in that it thinks the existing version is 5.1?
At any rate, I downloaded that, the DMG Launched fine, and was able to install over the previous and launched it without issue.
Next I went back and remounted the 5.0.0 image, copied that over the 5.0.1, and it launched fine. Finally I remounted the 5.0.1 image again, copied 5.0.1 over 5.0.0 and finally it launched.
