Download failed
DOWNLOAD FAILED
im having trouble downloading rhino
error says
"rhino setup could not download required packages from the internet. to fix this problem, either
  1. enable your internet connection
OR from a computer with internet access:
  1. run this installer.
  2. click settings
    etc…"
i tried to redownload it and download a different redist folder but im not sure anymore
In think you mean you had trouble installing Rhino for Windows.
You downloaded the Rhino for Windows installer successfully.
It was running the installer where you had problems.
The Rhino installer generated an error message with a link to an error log.
Please follow the instructions to save it and send it to tech support.
That will help determine what went wrong and what the steps to fix it.
Thanks
will send the install log to tech support, hopefully it gets fixed
