Doubt grasshopper
Guys,
I need to make this pink mesh (from image 1) only be in the outline of that path (image 2).
That is, I need to cut with the outside
Anyone have an idea how I can do it?
I put the GH file if help
Curves.gh (18.5 KB)
Use the cull pattern component to get just the points inside your curve like this…
I think this will work for your def but I didn’t dig deeper into what else would need to change there :wink:
Hey!! Its not work for me! I was try to do :frowning:
BTW, tks a lot for help!
I think you’ll need to edit your definition after culling the points outside the curve. They are feeding into a logic I don’t completely understand in your original definition so I would suggest remaking the definition from scratch using this method of point culling based on a closed curve. I bet it will end up being more efficient too. Good luck!
