does shape diver plan to support Rhino inside Revit Nodes?
this could allow Revit geometry to be displayed in shapediver and Revit parameters to be changed.
at the project level or even at the family level
Where would Revit be installed?
As Luis mentioned above, this would require our servers to have instances of Revit running in the cloud. The folks at McNeel have always supported our use of cloud instances of Rhino. Building similar environments with Revit instances is not realistic at the moment. Not only is Revit not usable in a headless environment but mostly it is not imaginable to reach a licensing agreement with Autodesk that would cover this use case.
Have you heard of the recent news though? ShapeDiver has merged with Swarm and will integrate its desktop client for (among others) Revit. This will allow ShapeDiver users to build workflows where a Grasshopper definition uploaded to ShapeDiver can be controlled directly inside Revit, using Revit elements as inputs and outputting them as well directly in Revit documents. You can already try Swarm if you want to test an early version of this feature.
ok i will take a look at swarm
this merger will not happen until 2021?
That’s right. The goal is the have a unified platform around Q1 2021.
ok
also it looks like shapediver does not support custom gh files
except a few such as Karamba?
is there a list of supported gh/ grasshopper plugins?
almost all of my GH scripts have custom GH components
This is the list of supported plugins on the shared system.
Note that with an Enterprise account, you are able to install any third-party plugins and libraries.
