Does Clipper2 variable offset only work on XY?
I noticed Clipper2 variable offset only works on XY plane?
On XY:
Same polyline, rotated 90:
Is this normal? Clipper 1 doesn’t have variable offset
I think most of Clipper stuff works on XY plane
I usually orient stuff on XY then inverse transform to move them back to their location
Thanks Inno - regular Clipper2 Offset does have plane input option, but not the variable one. So I’ll copy your inverse-transform method!
Cheers!
