I bought an ‘low poly tomato plant’ and inserted it into Rhino. It has these strange sheets, does anyone know what to do to make it render like a plant? I received some bitmap textures with it I believe.
Thanks very much ![]()
Cal
Cal
Are all those sheets one mesh? If you try to select it, the whole thing is highlighted yellow?
Try to make a material and apply the texture that came with it as the color of the material. It looks like they are low poly sheets to place image textures of a plant with some opacity/masking so you only see the leaves
G
Yes, they are meshes that normally would have Alpha channel textures on them of leaves. That would make it look like a plant. Here are examples: Plant Alpha textures
