If i use the scale component I would be making the cells smallers but if you look at the img thats not what i need, all the cells are of same dimensions . I need to limit the number of hexagonal cells around a point ( gradient achieved through point attractors).
Hello
Welcome to the forum. Such low documented question has low probability to get a correct answer.
You must do a good search to find examples on this pattern. With BMW keyword you’ll find some discussion on this forum. Then post a script in order to be helped.
