and when i clic on an optiion eg where there is the arrow, what happens is that thew option choose is not “Testo” (text) but “Aggiornamenti e statistiche” (updates and stats)
If you installed English in addition to Italian originally, it will be available in the uppermost dropdown list under Appearance (Aspetto?), you can change it there. You will need to close and restart Rhino for the change to take effect.
If you didn’t install English originally when you installed Rhino (it will not be in the dropdown list above), you will need to add it. To do so, close Rhino, go to Windows Control panel > Programs > Uninstall or change a program, find Rhino 6 in the list, right click and choose “Change”. In the dialog that comes up, click “Modify”, “Select languages” and add English, then press the “install now” button. When done, go back to Rhino and do as in the first paragraph above to choose English.
The problem is that to choose Englisch appearanace you are in the same panel that gives error, i can choose appearenace but than i cannot change langueage
Well, if you did install English, try copying the following script file to your desktop, then from inside Rhino type _RunPythonScript, browse to the script and open. Then close Rhino, and re-open. If all goes well, Rhino will then be in English…
For the SR version, Help>About (Aiuti>Informationi su Rhino).
That’s why the script didn’t work. From my post above:
Close Rhino, go to Windows Control panel > Programs >Uninstall or change a program, find Rhino 6 in the list, right click and choose “Change”. In the dialog that comes up, click “Modify”, “Select languages” and add English, then press the “install now” button.
Then you can either try to set English via Options, or try the script again.
Hi, This link is on how to add languages in Rhino 6.
Having said that, please type: _SystemInfo (enter) on the command line and paste the content.
If you need to email me in Italian: giuseppe@mcneel.com
Adding a language will get you going, but I’m afraid it will not fix anything.
I was asking for your Rhino SystemInfo so that we can look into the problem.
Without that we don’t have a place to start.
