Changing language issue rhino 6
Hi everyone. I need your help, please. Does anyone know how to change language in rhino 6 evaluation version? I need english to work on it.
It’s under File->Property->Appearance
Top menu item.
If you don’t see English as your selection, if you run the installer again and on the
right bottom there is a setting like icon, which you press to select the language to be
installed.
Then go file->property->appearance.
