Hi
I have many branches in this file ( at the end of file ) and i want to divide final list to sublist that each list has each branch.i want do it automatically because in each geometry i have different section number. finally i want write them to excel in separate columns.
thanks for your help!
for mcneel.gh (21.2 KB)
Hi.
Can you explain this again?
There is the “Partiton list” or you can graft your datatree.
It’s unclear what you need.
for example , in the file i have 4 intersection curve and many points on them. numbers of points on each curve are different and i want to divide the list and have each branch separately.
finally i want the points in each branch separately and write them to excel.
He is referring to this thread:
for mcneel_re.gh (23 KB)
With Explode Tree (BANG!) component you can pick one branch at time.
Or you can use @Joseph_Oster’s tool “vTrE” (that you have already on your file) to pick one.
Then you can use ‘tab’ character to get your data ready to be exported to excel with copy-paste.
Many other solutions are possible. If you use plugins you can direct export into a excel file… i don’t use them so i don’t actually know the name of those plugins…
Edit: seems like you have already quite some answers for your problems, @a.mazloom72 .
Try to “combine” what you have now…
