Divide surface using different spacing distances - Paneling
Hello! I’ve been working on this parametric panel for a while and I’m struggling to modify the grid in the x direction (so that the spacing looks like the curves in the left). I want the division of the inicial surface to vary randomly between 3 values: 0.235; 0.335; 0.435.
WhatsApp Image 2023-09-07 at 16.44.49
panel secotr.gh (32.4 KB)
What an honour
Hi @emilia1 ,
After messing around with the surface UV domains I found it was faster to just exploit the dash/gap pattern of the surface X border line.
I think this achieves what you are after?
You can establish your possible values and then randomize the pattern by changing the seed value slider.
Graph Space Pt 1:
Graph Space Pt 2:
Model Space:
Hope it helps!
20230907_panel secotr_Response_01a.gh (37.7 KB)
Thank you so much Michael! That’s exactly what I needed
Great! I’m glad it helps!
